[FOR SALE] Used Big Block Lunati Hydraulic Cam
Heywodja
The Heartbeat Stops Here
Texas
85.00 plus the ride.
Used cam looks to be in good shape, no wiped lobes.
Too big for my application.
Drag Race Hydraulic Flat Tappet Cam - Chrysler 361-440 285/295
Product Description
The Lunati Drag Race Cams are available for a wide range of racing applications from Sportsman to Pro. These camshafts produce unmatched torque for launching the vehicle off the starting line and maximum horsepower for a strong finish. Custom grinds are also available.Hydraulic Flat Tappet. Good cam for high performance street and mild racing applications with 383- 440 c.i. motors. Needs 3000-3500 RPM stall converter, headers, 10:1+ compres- sion ratio and 3.90+ gearing. Rough idle.
  • Advertised Duration (Int/Exh): 285/295
  • Duration @ .050 (Int/Exh): 235/245
  • Gross Valve Lift (Int/Exh): .507/.534
  • LSA/ICL: 110/106
  • Valve Lash (Int/Exh): Hyd/Hyd
  • RPM Range: 3000-6500
  • Includes: Cam Only
Part Number: 10210906
Previous Part Number: 30306
Lower price 60.00 plus shipping
