V6 Mechanical Advance Electronic Ign Distributor?
Small Block Mopar Engine
  1. rdunnam
    rdunnam RDunnam
    55
    12
    May 31, 2011
    Tupelo, MS
    Local Time:
    8:55 AM
    Looking into carbing or Holley Sniper on my V6 that was replaced with 5.9 Magnum in '89 P/U.
    The V6 is an option for the Willys CJ2A project, however, is there info out there on converting a V6 distributor (computer controlled type) to one with a 6 point reluctor, similar to the standard OEM V8 electronic ignition distributor, but with maybe a slant six point reluctor and having mechanical and vacuum advance? What have folks done on this situation?
  2. Garrett Ellison
    Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
    2,922
    2301
    Jan 1, 2018
    Southwest VA
    Local Time:
    9:55 AM
    Do you have a pic of your distributor? Although it's been a while since I've seen one, I'm thinking you can use a standard small block V8 distributor, put a 6 point reluctor wheel in and put the 6 cylinder cap and rotor on it.
  3. Professor Fate
    Professor Fate Push the button, Max...
    1,040
    1303
    Jan 13, 2020
    Wisconsin
    Local Time:
    8:55 AM
    If you go with the Sniper system, wouldn't you be able to use the stock distributor? IIRC, it's a hall effect distributor with no advance mechanism, and the Sniper should be able to enable spark control on that, since it would need to be locked out anyways...
    If you go carb, I'd look for an '87 distributor out of a Dakota or full size truck, I BELIEVE those were pre-TBI, and still used a carb, although it was a mutant semi computer-controlled thing...
    • Agree Agree x 1
    • 67Dart273
      67Dart273 FABO Gold Member FABO Gold Member
      45,144
      12785
      Oct 14, 2010
      Idaho
      Local Time:
      6:55 AM
      I'm not sure they made such a thing, that is with advance. "I think??" all Chrysler V6's were electronically controlled advance. I'm thinking "the first couple years" were TBI EFI and would likely have had a reluctor
      WHAT IS THIS? This is a 89? what? 3.7?
      A quick Google claims the Dodge v6 came out in 86
      Also you might look into whether a slant reluctor will fit a V8 distributor, and whether the early V6 caps and rotors will fit a V8 distributor.
      This below came off the All-Par site, so looks "maybe" up through 91 is a possibility
      In 1987, its first year, the 3.9 used Holley 6280 two-barrel feedback carburetors. This setup may have lasted into 1988 on Dakotas, but then Dodge slapped an EFI intake and induction on the 318 and the 3.9. They shared a Holley throttle body, until the Magnum versions, and used a non-vacuum advance distributor. One engineer wrote, “I remember they had an awful time with the fuel/air distribution. We were all asked to help out if we had a glimmer.”
      From then until the 1991 models, they used single-point fuel injection— relatively inefficient, but easier to control and maintain than a carburetor.
    • 67Dart273
      45,144
      12785
      Oct 14, 2010
      Idaho
      Local Time:
      6:55 AM
      Have you looked inside? Found this diagram? Looks like it should have a reluctor just no advance
      xHIlinkaO8n_HiFt3w0PTSNw_JKNvZrEANnIe4FzrcDybWKMS25amBbrfawEjvd380zlr3TGclzlUBevAsmjSq-SKQrlqBCM.gif
    • rdunnam
      rdunnam RDunnam
      55
      12
      May 31, 2011
      Tupelo, MS
      Local Time:
      8:55 AM
      You are most likely right on the sniper controlling the ignition advance, I was thinking along those lines.
    • rdunnam
      rdunnam RDunnam
      55
      12
      May 31, 2011
      Tupelo, MS
      Local Time:
      8:55 AM
      They didn't make such a thing so I was asking if anyone "fabbed" up one that would work. Somewhere I read that a slant six reluctor on a v8 distributor set up would not work because the v6 engine is an "uneven" firing engine, does not fire at 120 degrees "evenly" during the two rotations (a complete combustion cycle), it's designed to fire on 117 and 123 degrees, something of that sort. I'm asking. Using the stock distributor with a stand alone controller or let the Sniper control the timing may be only way.
      • Agree Agree x 1
      • abdywgn
        abdywgn dismantler
        1,493
        740
        Jul 30, 2006
        Darien, Illinois
        Local Time:
        8:55 AM
        check an old DC catalog...thought they had a performance conversion kit similar to the V8's.
        • Agree Agree x 2
        • rdunnam
          rdunnam RDunnam
          55
          12
          May 31, 2011
          Tupelo, MS
          Local Time:
          8:55 AM
          Distributor and engine is '89 3.9L is out of a D100. Design is LA small block minus two cylinders, then they added the magnum features to it about same time as the LA was updated to magnum.
        • Garrett Ellison
          2,922
          2301
          Jan 1, 2018
          Southwest VA
          Local Time:
          9:55 AM
          From what I am finding, all 239 V6 distributors were all cam position sensor units like the V8 went to during Magnum production. No reluctors were made for the 239 v6 unless there was an MP unit.
        • rdunnam
          rdunnam RDunnam
          55
          12
          May 31, 2011
          Tupelo, MS
          Local Time:
          8:55 AM
          Distributor's between those basically same, computer controlled in some fashion, I know the 88-91 is like mine with FI, it actually has an ECM, 87 did have the feedback style carb not sure what type computer, may have been a mutant like you said of the lean burn system like my 84 has (/6). Thank you.
          • Like Like x 1
          • rdunnam
            rdunnam RDunnam
            55
            12
            May 31, 2011
            Tupelo, MS
            Local Time:
            8:55 AM
            That sounds correct. Same thing I've found from researching it. Thank you.
            • Thanks! Thanks! x 1
            • rdunnam
              rdunnam RDunnam
              55
              12
              May 31, 2011
              Tupelo, MS
              Local Time:
              8:55 AM
              I read that also. Now that would be a hen's tooth. Are those old DC catalogs online now by chance. I don't have a hard copy of one. Thanks.
            • Professor Fate
              1,040
              1303
              Jan 13, 2020
              Wisconsin
              Local Time:
              8:55 AM
              Conversion kit for 3.9 V6: P4529402- includes dist., harness and orange box.
              Distributor only: P4529401.
              Good luck hunting those down!
              On a side note, they also made one for the 2.2/2.5L four bangers... now that's gotta be rare...!
              • Agree Agree x 1
              • 93ragtop
                93ragtop Well-Known Member
                181
                98
                Dec 23, 2015
                Va
                Local Time:
                9:55 AM
                I have heard of some using the V8 dist. with a slant 6 reluctor.....
                But I dont see how it would work. My understanding is, the slant 6 is equal fire engine, 120 degrees.....
                The 3.9 V6, being it is from a 5.2 V8 is odd fire. And I thing it was at 112 and 128 degrees.
                One possibility I never really checked into, would be maybe using a V8 GM HEI style dist. made for a SB mopar. Then using a reluctor and cap from one of the odd fire GM v6...... Lots of ifs and maybe's in that statement.
                Personally, I became flustrated and decided to go V8 in my dakota....
                Kinda off base, but I had a guy tell me, the only thing more rare then HP parts for a 3.9 V6 is customers wanting them!!! Sad, but I think its true.
                Oh, and if your interested, I think somewhere I have the part number for the reluctor that was used in the MP V6 electronic ign. dist. Let me know....
                • Like Like x 1
                • RammerJammer75
                  RammerJammer75 Well-Known Member
                  538
                  679
                  Aug 28, 2020
                  Kingsport, TN
                  Local Time:
                  9:55 AM
                  With the Sniper system, would it be possible to use the stock style distributor and wire the pigtail into the Holley harness? I'm pretty sure the first 3.9 engines were carbureted, but I'm not sure if the distributor was electronically controlled.
                  • Like Like x 1
                  • 93ragtop
                    181
                    98
                    Dec 23, 2015
                    Va
                    Local Time:
                    9:55 AM
                    The 87 used a carb. holley 6280. It was an electronic feedback carb. There is a computer on the pass. fender. The computer controls the 6280 input, (I think the power valve) and it controls timing.
                    The dist. is the same for 87 (carbed,) and 88-91 TBI
                    • Like Like x 1
                    • Agree Agree x 1
                    • rdunnam
                      rdunnam RDunnam
                      55
                      12
                      May 31, 2011
                      Tupelo, MS
                      Local Time:
                      8:55 AM
                      Once or if the willys jeep project materializes, I may try to find a later model v6 magnum setup, ecm, harness, FI, retain it all. My v6 was the 89 TBI, the later set up may be more favorable if I'm going through the trouble of going that direction. Thanks for all your input and info!
                      • Like Like x 1
                      • Garrett Ellison
                        2,922
                        2301
                        Jan 1, 2018
                        Southwest VA
                        Local Time:
                        9:55 AM
                        FWIW, your TBI V6 cam for the 1.5 rockers can be used in your Magnum engine and have increased lift and .050 duration with the 1.6 Magnum rocker ratio. It's a good upgrade and still plays well with the Magnum electronics. Shortening the runners in the "kegger" intake helps, too.
                        • Agree Agree x 1
                        • RammerJammer75
                          538
                          679
                          Aug 28, 2020
                          Kingsport, TN
                          Local Time:
                          9:55 AM
                          If the OP is after more torque, I don't think I would cut the runners down. But maybe a short amount wouldn't hurt.
                          • Like Like x 1
                          • Professor Fate
                            1,040
                            1303
                            Jan 13, 2020
                            Wisconsin
                            Local Time:
                            8:55 AM
                            • Garrett Ellison
                              2,922
                              2301
                              Jan 1, 2018
                              Southwest VA
                              Local Time:
                              9:55 AM
                              Surprisingly, the Magnum V6 makes a little more power on the bottom with the runners trimmed back, too. However, it is a pretty small gain for the effort. Confirmed by a friend who was partial to the magnum v6 for off road duty with low gears. One of those vehicles that doesn't get there quickly, but lugs down and crawls through stuff that gave other vehicles the fits.
                              • Like Like x 2
                              • rdunnam
                                rdunnam RDunnam
                                55
                                12
                                May 31, 2011
                                Tupelo, MS
                                Local Time:
                                8:55 AM
                                How do the stock '88-'89 TBI V8 cams (roller correct?) w/1.5 rockers work in the later '93 up magnum w/1.6 ratio rockers? Are they spec'd w/slight increased lift and duration as well?
                              • Garrett Ellison
                                2,922
                                2301
                                Jan 1, 2018
                                Southwest VA
                                Local Time:
                                9:55 AM
                                I haven't been able to find new replacement LA rollers with stock lift specifications but putting an LA cam into a magnum makes a noticeable improvement if you have a usable stock LA roller on hand. The LA 360 is your first step up the ladder and the LA 318 hydraulic roller would be the hotter cam choice. There's usually a crosswind type intake involved in the mix whenever I've been involved with the swap and it makes a before and after difference you can feel. I will have to find the stock lift chart to share with you for the specs but here's a W100 with a 5.2 Magnum and 360 LA roller with a crosswind and a 650 Edelbrock. It's got 31X10.50 and 3.21 gears with a HD four speed but there's no shortage of torque. Lower gears would really help, though.
                              • rdunnam
                                rdunnam RDunnam
                                55
                                12
                                May 31, 2011
                                Tupelo, MS
                                Local Time:
                                8:55 AM
                                Not sure if I would use...or maybe, stock specs on LA, LA-pre mag, and mag cam specs would be interesing side by side. Just for fun. Mine is a "re-grind" for my 5.9L is by Bullet Cams, .525 lift w/ 1.6 rocker, .218 and .226 duration, 112 LSA. Eddy RPM performer intake. EQ heads w 2.02 SS intake. 1989 D100 2 wd. What about that Duster in the profile pic?
