v8 federal power steeringm pump pulley
69 Valiant Kid
wisconsin
Rating - 0%
0   0   0
does anyone have a v8 federal power steering pump pulley? i have the slant 6 pulley and that one sticks out too far past the crank pulley. maybe they dont even make one but i thought they did. thanks guys
I've got a pump that worked on my '76 duster with a V8 and power steering. Do you have a pic? I'll check this one, and you can have it for $5 plus shipping if it works for you.
mike
hey valiant kid,do you have a slant six in your car?if so you need the additional pully that bolts to the front of the crankshaft pulley,I have several of them,e mail me(be descriptive)[email protected] if it is V-8 you need a diffrent crank pulley
anyone, i need a v8, federal power steering pump pulley, or pulley and pump together...i know they are out there. please help i would like to get this car running!
I just did that swap on my 64. I went with a saginaw pump(mopar) and a march performance ps bracket... The oem federal pump mount didn't line up, the later model water pump doesn't have the needed mounting hole.
Bob
bob, the bracket i got from mancini racing...the federal bracket fits, i just need a v8 pulley and not a slant 6 pulley....
I have the whole pumps from a 68 Barracuda V8 car and one from a 69 V8 car. Either one of those work?
do you have the brackets for them?...and does the center of the pump where the pulley slips on, is it press fit with threads in the middle of the shaft...and does the cap have 2 tabs on the opp ends of each other?
Pick one!:-D
