vacuum/engine question
whitey
Andreas, Pa (near Allent
This may sound like a dumb question, I have a comp cams xe268 cam, non-adjustable vacuum advance distributor from Mancini. When the rpm goes up, should vacuum go up or down?
The port for distributor vacuum is used to add more advance in light load (often cruise) conditions when the engine can accept more vacuum. Net is that is very dependent on engine load - mash the throttle and vacuum will drop substantially - even at a fairly high RPM.
Depends on the throttle blades amount of opening.
