Valley pan gaskets
swedefish
Sweden
How do you guys seal your valley pan /intake gasket on a mopar b-engine.
Do you use any kind of sealer against the head, I´ve heard and read of those who don´t use any silicon or similair and those who use it.
What´s the best way?
Any info is appreciated.
If the geometry's right you don't need a lot or any sealer what so ever.
BUT I use a lil all around the outer edges of the pan and tiny bit below & around the ports not so much that it squishes into the port, just a thin skim coat.
Spray permatex copper coat on all the sealing surfaces.Done all this way
without any problem but could go back to that geometry thing if parts
have been milled/decked improperly.
