What do you guys use for valve cover hold down tabs? I have the stock 440 valve covers and they're warped and leak, I replacing with set of Edelbrock stamped steel chrome valve covers. I am putting studs in the heads and using flanged bolts, but wondering if I should use some tabs to distribute the pressure? Also should I use I sealer on the valve cover side of the gasket?
