Abodies Only
New Member
I purchased a rebuilt motor complete less the tin. My question is without knowing the cam what is the lash setting I should use. It is presently set at .018 and .018 thanks in advance Brent
Thanks Dan , will it hurt anything if I try .010 on the intakeIf it's got any of the three stock cams ('60-'64; '65-'70, '71-'80), then it's 0.010" intake and 0.020" exhaust, hot. See valve adjustment article.
Hi Dan I’m not sure what the cam is if it’s factory or been upgraded I bought the motor in crate with no information other then it was rebuiltYou're welcome, but I don't understand the question. 0.010" is the factory spec for the intake lash.
