I just swapped my cam from a small stock cam to the Mopar performance .509/292 cam. the motor is a 67 440 and I am currently running bone stock 906 heads. I am planning on breaking in the cam with the current valve springs then swap out for the recommend springs. I have found a couple different sets that seem appropriate for my setup the first was a crane double spring, but this spring will require machine work to the heads (I am trying to avoid as I will be swapping the heads later on for a set of eddys) the second choice are the mopar performance springs (5249848), what I am wondering is if the heads will need to be machined to accept these springs? I tried to call Mopar with no luck, sent a question to the tech department with no answer. Below are the specs on the springs.
Number of Springs Per Valve: Single
Outside Diameter of Outer Spring (in): 1.554 in.
Damper Spring Included: Yes
Inside Diameter of Outer Spring (in): 1.130 in.
Inside Diameter of Inner Spring (in): 1.032 in.
Valve Spring Style: Standard
Valve Spring, Single, 1.554 in. Outside Diameter, .480-.540 in. Lift Range, .216 in. Wire Diameter, Each
As always any help is appreciated.
Greg
Greg
