Valve spring ID
Johnschummer
Feasterville, PA
Can any of you guys tell what valve springs these might be? Comp 901-16? They came out of a 360 that had a factory cam with 974 heads that had these different looking retainers. I would like to use them with a 340 build running a melling Spd-22. I also have access to a set of Hughes 1110p still in a retired engine of my brother.
No way to know what spring it is by looking at them. You can measure them with a spring tester and get the load, then measure wire diameter and you might be able to match them up to a published spec for a certain spring but that’s as close as you’ll get.
