Valve Spring Removal Tool for Trickflow 190 heads
rslscobra
Michigan
I am looking to remove two valve springs to check piston to valve clearance. My question is which tool works on removing the valve springs with leaving the head on? They are dual valve springs too. Thank you!
Something like this, but for LA motors if that’s what you have. Plus a way to keep your valves up. Compressed air or smoosh some rope in there approaching tdc.
Here ya go, in all its badassery. I use these on my big block and small block trickflows.
That one works for single valve springs not dual. Ty
I’ve used the loaner one from AutoZone and O’Reillys that looks like the Lisle one pictured above. Absolutely a PITA, even on single Springs. Do yourself a favor and get a quality tool like the one shown above. Just speaking from personal experience.
