Vapor (Water) Shields
'64 Dart
NW Ohio
Good Evening All
Are there any sources for the water shields that go behind the door panels for our beloved Mopar A bodies? I can find lots of sources for GM a bodies but zippo for Ma Mopar.
I can make what I need, but would like to find 'plug/n/play' ones for a '67 Dart Convertible.
Thanks to all who respond.
'64 Dart
Be careful if you make your own in choosing material. Pulled door panels off a 70 Duster not long ago and the sheets were there but brittle and busted in a few spots. I talked to the owner and he had made sheets and installed them with the door panels 4 years earlier. Whatever the material was didn't last. I've seen perfectly good factory sheets that were 50 years old and still very flexible.
Thanks 70SwingerGuy for the link.
They show shields for the Barracuda but not for the Dart in '67.
I'll call them Monday and pick their brain.
Thanks again
'64 Dart
Good Evening All
'64 Dart
Here is a source,
Custom made for your application including putty.
Door Window Moisture Barrier Water Plastic Sheet Mopar
