investigator
I am enclosing one of my drawings of my starter relay wiring please tell me if this will function properly as far as starter operation goes thank you in advance
Thanks for the reply have a 10 gauge running from the battery post through the drilled holes in my firewall connector directly into the passenger compartment that is going to supply the old amp meter Loop since it has been disconnected from the amp meter it has a 30 amp fuse and a 30 amp switch.Yep! That's it, the other wire on the battery post usually would feed the fusible link.
Yes but made some minor modifications will get back later battery is dying thanks again for your help have a great dayLook up MAD wiring diagram. Sounds like someone may have did it.
Catalog
