My FSM shows 145 ft lbs torque for the lower control arm pins is this
correct? Seems kind of high. Also, I cannot find a torque for the upper
control arm cam bolt nuts anywhere, is there a recommended spec or
should I just go with standard for a 1/2" bolt?
