I’m sure glad I have no use for one of those.
Single head? It needs to go on a 4 cylinder. (4 cylinder LS thread?)
Or if someone dropped a valve and muffed one up.I could see if someone had a head, was in love with that head, had access to tooling to do the needed work, felt like wasting money, felt lucky. Ohhh never mind. Lol
Or garden sprinkler!Seems like it would be an expensive wheel chock
I've seen a few of those for sale over the years. Can you imagine how much money you'd have in a pair of those ready to race.
I paid the porter a few hundred and opted for used Ti valves 1 season old ($800) & valve seals. Springs, retainer and locks go with the price of a cam and lifter set up. Since there were none on the bare head, they need to be for the cam to be used. Not part of the head cost. Springs, locks and retainers are cheap.And add 2 grand to finish it.
Methanol injected 400 horse?Mopar Performance used to sell an aluminum "half LA" block specifically for midget cars, for use with W-series heads (primarily 7 & up, but one could be resourceful). It was called "A4"; the catalog part number was P5007466 and the casting number was P4510025.
Not sure where you see guides..At least it is machined for valves and guides .
There were a bunch of really raw heads floating around a few years back . They were from a pallet of heads for the Truck Series that were left over when the moved into W8s or 9s…. Something to that effect . Can’t say Im very knowledgeable on circle track stuff. Problem was that no one knows where the CNC program went for them .
My early Commando a heads were rough so rough the dog looked at them and agreed .And add 2 grand to finish it.
ummm… errrr…. Gulp…. Lol
I bought 4 pair from Lee Millers auto. He bought several pallets of engines and parts from Ray Evernham when he went to GM in Nascar. Lee raced Nascar truck series. He still has tons of parts on shelves including complete race engines with W9 top ends. I took a bunch of W5 and W2 top ends out to Ryan Johnson at Shady Dell . He screwed me on everything. X blocks , Batten Heads, Everything disappeared.
Lee Miller still has more Parts then you can imagine. He says he don't but I been in the upstairs of the shop. I found the only W5's that are worth anything are some with blue pipe plugs. All other have bad porosity problems and don't hold seats or guides the aluminum starts flaking away. Indy 360-1 rectangle CNC port heads Make more power then others for less money . Unless you can find a set of the first W2 rectangle port Batten heads designed by Oldsmobile. But then get ready to put tons of money in them.
There is another shop in Lansdale with a stash of 64 Max Wedge top ends. But then that **** is out dated now compared to some of the later aluminum heads. The old **** is great to look at but gathering all the parts to use them is crazy. And when you break something your on a year long hunt for parts.
