Vibration right off idle
Transmission and Drivetrain Tech
  1. plumkrazee70
    plumkrazee70 Well-Known Member
    2,882
    860
    May 5, 2013
    Medford, Oregon
    Local Time:
    6:55 AM
    The engine, while relatively new has been run with the 904 behind it for a very short time. This can't be. Misfire. I can feel it in my seat.
    • Like Like x 1
    • George Jets
      George Jets 1967 Dart 2 Door FABO Gold Member
      4,469
      6075
      Jan 18, 2019
      Farmington MN
      Local Time:
      6:55 AM
      OK if you can feel it in your seat, that is telling you that the transmission is making contact with the tunnel and transfering the vibration through the floor up to your seat.
      Yes, scratch the misfire then.
    • Phreakish
      Phreakish Well-Known Member
      1,225
      809
      May 28, 2015
      N. Idaho
      Local Time:
      4:55 AM
      That's good info to have. At least you know it ran right before the swap.
      • Thanks! Thanks! x 1
      • plumkrazee70
        2,882
        860
        May 5, 2013
        Medford, Oregon
        Local Time:
        6:55 AM
        I'm gonna put it up high on stands tonight after work and check it out.
      • CudaFactHackJob
        CudaFactHackJob FABO Gold Member FABO Gold Member
        1,651
        623
        Mar 17, 2016
        Hemet, Ca.
        Local Time:
        6:55 AM
        Does it vibrate driving with the engine shut off?
        • Like Like x 1
        • plumkrazee70
          2,882
          860
          May 5, 2013
          Medford, Oregon
          Local Time:
          6:55 AM
          I haven't tried that yet. I did read that as a place to look when I was researching last night.
        • plumkrazee70
          2,882
          860
          May 5, 2013
          Medford, Oregon
          Local Time:
          6:55 AM
          Ok, so I think I got the vibration off idle, fixed. I looked all around the trans and all was good, but I noticed that my driver's header was touching the torsion bar. So I used a pry bar and put a wood shim in there and tested it on stands and it appears that noise vibration is gone. So I need to fix that. While doing so I noticed that I have two different motor mounts (rubber) so I need to fix that and level the engine and retest. Ugh... I created a new thread in the SB engine section seeking help to confirm what I need.
          • Like Like x 1
          • 512Stroker
            512Stroker We are all here because we are not all there.
            2,310
            1675
            May 30, 2016
            Freedom, MO
            Local Time:
            6:55 AM
            While you are under there, if possible, take the torque convertor bolts out rotate the convertor 180 degrees and reapply the bolts.
            See if that changes your vibration
          • Brooks James
            Brooks James Dustoff
            833
            438
            Dec 12, 2020
            Fruitland Park Fl
            Local Time:
            7:55 AM
            What’s the story on the harmonic balancer??
          • plumkrazee70
            2,882
            860
            May 5, 2013
            Medford, Oregon
            Local Time:
            6:55 AM
            Good idea. I did check the torque.
          • plumkrazee70
            2,882
            860
            May 5, 2013
            Medford, Oregon
            Local Time:
            6:55 AM
            It's new and I checked the timing and it's still good.
          • CudaFactHackJob
            1,651
            623
            Mar 17, 2016
            Hemet, Ca.
            Local Time:
            6:55 AM
            I'm just staying in here for the laffs at this point..
            • Disagree Disagree x 1
            • plumkrazee70
              2,882
              860
              May 5, 2013
              Medford, Oregon
              Local Time:
              6:55 AM
              Laffs? You mean laughs? Was something funny?
            • CudaFactHackJob
              1,651
              623
              Mar 17, 2016
              Hemet, Ca.
              Local Time:
              6:55 AM
              Not yet..I'm waiting for you to turn that converter 180 degrees..lol..or should that be haha?
              • Agree Agree x 1
              • 512Stroker
                2,310
                1675
                May 30, 2016
                Freedom, MO
                Local Time:
                6:55 AM
                Dont laugh to hard partner.
                I personnel saw rotating the convertor cure a vibration on a $120K street rod.
                I know theoretically it should not work, but, it does not cost any $ to give it a try.
              • CudaFactHackJob
                1,651
                623
                Mar 17, 2016
                Hemet, Ca.
                Local Time:
                6:55 AM
                Ok then, I'll hold my breath starting right now...lmk when you get those last two bolts to go in..
                • Agree Agree x 1
                • 512Stroker
                  2,310
                  1675
                  May 30, 2016
                  Freedom, MO
                  Local Time:
                  6:55 AM
                  Well you may be right.
                  I know on my 727 there is one offset hole.
                  Not sure what they do on the OP's setup
                  The street Rod had a GM system
                • plumkrazee70
                  2,882
                  860
                  May 5, 2013
                  Medford, Oregon
                  Local Time:
                  6:55 AM
                  I gotcha now. I can't remember if the A500 had an offset hole or not. It's the same plate as the 904.
                  I have to sort out my motor mount situation and go from there.
                • CudaFactHackJob
                  1,651
                  623
                  Mar 17, 2016
                  Hemet, Ca.
                  Local Time:
                  6:55 AM
                  Ya, they're all offset...sorry for pickin on you guys...too much Monster..
                  • Like Like x 1
                  • plumkrazee70
                    2,882
                    860
                    May 5, 2013
                    Medford, Oregon
                    Local Time:
                    6:55 AM
                    Ok, so I got new biscuit rubber mounts and the motor is sitting level side to side and so is the trans.
                    I wanted to get your guys opinion on where to measure for pinion angle? For the transmission, I've measured on the pan rail and the end of the tail shaft and I get two different angles. Same goes for the pinon, I measured on the bottom flat, and also the flat of the yoke. Once again two different angles.
                    If I go by the trans tail shaft I get DOWN 2.5* and the flat bottom of the pinion is DOWN 3.9* I used the Tremec App and it will only go green if the pinion is at a max of 3* DOWN.
                    What I don't understand, is all I read is that the pinon needs to be parallel with the trans under load. To be parallel wouldn't the pinon need to be at 2.5* Up under load?
                  • 512Stroker
                    2,310
                    1675
                    May 30, 2016
                    Freedom, MO
                    Local Time:
                    6:55 AM
                    Then only place to measure the tranny angle is the tail shaft. Likewise the only place is the pinion yoke for the rearend.
                    You are correct the trans must be tipped up (positive), rearend tipped down (negative).
                    I set mine so they are as close to same angel (-/+) so the tranny and the rearend are parallel.
                    Sounds like you have a bum transmissiom mount.
                    I had to shim both to get it correct.
                  • plumkrazee70
                    2,882
                    860
                    May 5, 2013
                    Medford, Oregon
                    Local Time:
                    6:55 AM
                    Thank you. I'll re measure at the pinion yoke tonight, to confirm measurements. I have an A500 so it's not stock, but the mount is new.
                    I'll see if I can shim the trans up. When you say you had both angles the same +/- (trans up, pinion down) was that at rest or calculating the pinion rising x degrees under load?
                  • George Jets
                    4,469
                    6075
                    Jan 18, 2019
                    Farmington MN
                    Local Time:
                    6:55 AM
                    3° down at the rear end pinion angle as compared to the tailshaft angle sounds correct if memory serves me.
                    3° down under load comes up to 0° when you put the power too it and get on it.
                    Bump stop above the rear yoke is a safety stop to keep the rear angle from twisting up to high under load and taking the rear u-joint out.
                    Been a long time ago in the 80s when we were setting up new length drive shafts for extending frames and sleepers for semi-tractors, those were set at 1.5° down.
                    In my opinion, double check some more info and or call a driveshaft shop.
                    Good Luck
                    You don't want those driveshaft angles fighting each other. Kind of like some old PTO driven farm machinery when you turn too tight, the u-joints start rattling to beat heck, and is extremely hard on the u-joints.
                  • 512Stroker
                    2,310
                    1675
                    May 30, 2016
                    Freedom, MO
                    Local Time:
                    6:55 AM
                    At rest on my 4 post lift with the weight of the car on all 4 tires.
                    Try to keep the angles between 2-2.5 degrees and you should be good to go.
                    • Agree Agree x 1
                    • George Jets
                      4,469
                      6075
                      Jan 18, 2019
                      Farmington MN
                      Local Time:
                      6:55 AM
                      Yes ^^^^^ with the weight of the car on the 4 tires, not free hanging rear end in the air.
