Vibration right off idle
Transmission and Drivetrain Tech
  1. plumkrazee70
    plumkrazee70 Well-Known Member
    2,882
    860
    May 5, 2013
    Medford, Oregon
    Local Time:
    6:57 AM
    I have the car on ramps and it's level, so good there. Sorry, but are you saying keep both the pinion and the trans at 2-2.5*? And is that in both directions?
  2. 512Stroker
    512Stroker We are all here because we are not all there.
    2,310
    1675
    May 30, 2016
    Freedom, MO
    Local Time:
    6:57 AM
    Set the trans so it is pointing up +2.5 degrees
    Set the rearend pinion so it is down -2.5 degrees
    Negitive or positive 2 to 2.5 is just a range to shot for.
  3. plumkrazee70
    2,882
    860
    May 5, 2013
    Medford, Oregon
    Local Time:
    6:57 AM
    I don't think I can get my trans that high. I'll try shimming tonight.
  4. 512Stroker
    2,310
    1675
    May 30, 2016
    Freedom, MO
    Local Time:
    6:57 AM
    Try real hard or live with the vibration
  5. George Jets
    George Jets 1967 Dart 2 Door FABO Gold Member
    4,469
    6075
    Jan 18, 2019
    Farmington MN
    Local Time:
    6:57 AM
    Look at the trans on the right 904
    Then look at the overdrive trans on the left at how much longer it is than stock.
    Being your overdrive trans is longer, you end up with a shorter driveshaft and in the process it steepens your driveline angles.
    What is the tailshaft angle right now, car sitting level, and no shims at the tail shaft mount? 2° Negative ????
    Now measure the rear pinion angle, what is that, 2° Positive ???
    This is the senario you want with Negative degrees at the tail shaft and Positive degrees at the pinion shaft.
    Raising and shimming the trans tail higher is going the wrong way, giving you too sharp of a driveshaft to tailshaft angle.
    _________
    Let's see what your angle degree measurements are to start with.
    • Disagree Disagree x 1
    • 512Stroker
      2,310
      1675
      May 30, 2016
      Freedom, MO
      Local Time:
      6:57 AM
    • George Jets
      4,469
      6075
      Jan 18, 2019
      Farmington MN
      Local Time:
      6:57 AM
      Yeah that's a good article. ^^^^^
    • George Jets
      4,469
      6075
      Jan 18, 2019
      Farmington MN
      Local Time:
      6:57 AM
      Good:
      Bad:
    • CudaFactHackJob
      CudaFactHackJob FABO Gold Member FABO Gold Member
      1,651
      623
      Mar 17, 2016
      Hemet, Ca.
      Local Time:
      6:57 AM
      Ever notice how the carb is always level, but the drivetrain is tilted down in the back? And the manifold is angled about 3 degrees? You tilt the motor/trans down in the back about 3 degrees, and the pinion up 3 degrees. That article was written by a person who really doesn't understand driveshaft angles. Read his last post about Sunbeam Tigers. Driveshafts don't know the angles of the two units they are connecting, so up, down, left, right; don't matter to a driveshaft; only the overall angle; measured from any perspective.
    • George Jets
      4,469
      6075
      Jan 18, 2019
      Farmington MN
      Local Time:
      6:57 AM
      3° down at the engine/trany
      3°up at the pinion
    • plumkrazee70
      2,882
      860
      May 5, 2013
      Medford, Oregon
      Local Time:
      6:57 AM
      Sorry, guys. I missed these updates. All I have read is that you want what @George Jets is saying. (trans (-) and pinion (+) the same measurement to offset each other.
      So in my case: trans is -2.5* so my pinion needs to be at +2.5. Currently my pinion is -3.9*
      So if I roll the pinion up +6.5* that will give me a pinion angle of + 2.6 (-3.9+6.5).
      If the pinion rolls up 2* under power. Then I can subtract 2* from my shim. So I need to roll the pinion up 4.5*.
      Totalling .6* at rest and 2.6 under power.
      • oldkimmer
        oldkimmer FABO Gold Member FABO Gold Member
        19,049
        6301
        Nov 11, 2006
        Kindersley, Saskatchewan,
        Local Time:
        6:57 AM
        He posted them already. U absolutely do not want the pinion higher than the trans. The way u describe it he would have 4* positive. Kim
      • oldkimmer
        19,049
        6301
        Nov 11, 2006
        Local Time:
        6:57 AM
        No no no no no
