GrizandLinna
Member
I have a 1970 Dodge Dart Swinger with matching numbers 340 engine with a vibration. I think I found the source of my vibration and I have the right vibration damper on it. I took off the transmission inspection cover and come to find out that I have a different torque converter in it, painted orange and has weights on it. Instead of buying a new torque converter can I remove the weights from this and still use it? I have seen some Utubers changing torque converters with removed weights on them. I heard that is the only difference on the '71 and on up, mostly, is the torque converter weights. Is this feasible or am I being too cheap because it works just fine other than the vibration? Do you know of any venders for torque converters? Any advice would be greatly appreciated.
