New to this, what is a reloader??Crushed walnut shells work well too. Can get bags of it cheaply at any pet shop. Also a reloader here... ;)
What would you recommend for a liquid chemical?I dont know what media would clean threads as good as a liquid chemical.
Not sure whats best to remove rust, grease, everything. I use brake parts cleaner and a brush. I buy the Wearever brand by the case at the Carquest store. Affodable enough to spray a whole can in a butter tub. Close it up, shake it from time to time.What would you recommend for a liquid chemical?
I use 3 vibratory tumblers daily. Lyman 2500 Magnum's.
I too reload extensively but in answer to OPs original question, I agree with most all. Corn cob for delicate and SST pins for rough stuff. With regard to Lyman tumblers I have had good luck. I now use a Dillion and I like it better. Not because it does a better job but just because it is quieter. Lyman is relegated to backup.I've been looking at vibratory cleaners and it seems there are two classes, cheap junk and expensive commercial units. What kind of luck have you had with the durability of the Lyman units? (sorry for hijacking this thread a bit).
I use 3 vibratory tumblers daily. Lyman 2500 Magnum's. I rebuild Mopar door hinges and when the parts come from the manufacturer after heat treating they are dark and covered in oil. I Use Purple Power , less than $5.00 a gallon at Wal-Mart and let the parts sit in a bucket of it for 1/2 hour. Use heavy , long rubber gloves. This stuff is strong!! If the coating is real tough, a Scotch-Brite pad takes it right off. This keeps from contaminating the tumbler media so it will last longer. I have one tumbler full of Coarse Walnut shell, one with fine Walnut shell, and the last with treated corn cob. I spray a little Weimans Stainless steel cleaner in it from time to time. The parts come out with a high polish finish. This does not clean threads. A s/s wire toothbrush sized brush cleans the threads without damaging them. If you use a wire wheel on your bolts it is potentially dangerous if it slips out of your grip and it damages the threads. If these are not critical bolts... but if you need them to stay tight, pass on the wire wheel.
I use a Thumbler's Tumbler. Made for running weeks at a time polishing rocks, so a day or two with stainless steel pins is easy. No chemicals or dust, and you can't wear out the media.
All I have is a vibratory tumbler and not looking to buy anything else. Will the stainless pins work in this for cleaning rusted nuts and bolts?I use a Thumbler's Tumbler. Made for running weeks at a time polishing rocks, so a day or two with stainless steel pins is easy. No chemicals or dust, and you can't wear out the media.
So I noticed that you prefer the SS pins over walnut shells. What was the outcome of using the walnut shells on nuts and bolts? I don't plan on doing any brass.I’m not sure. I don’t want to say they won’t work with a vibratory tumbler, but I honestly never even tried the SS media in mine. I bought the media and Thumblers tumbler together.
It can’t hurt to try. I’ve had my stuff for almost 11 years, and for the life of me I can’t remember what it cost. And I’m still on the original media.
Funny thing is, I have a very weird side. I can’t stand dirty brass, and the tumbler like you have would never clean the primer holes in my brass. Drove me wild. What I have now will clean the primer holes to a fine sheen. That I like.
That’s just an FYI. I know many guys don’t care about a dirty primer hole, but like I said, I’m weird. Clean is clean.
Pins don’t work well in a vibratory. Need a rotary for them. I have two Thumblers and a Midway vibratory with three bowls. You can make a rotary tumbler any size you need. Lots of plans or videos out there. A big ultrasonic is tough to beat but the don’t come cheapAll I have is a vibratory tumbler and not looking to buy anything else. Will the stainless pins work in this for cleaning rusted nuts and bolts?
I tried the ultra sonic cleaner too. Not happy with the results. My Thumbler's Tumbler is the best there is. The stainless pins last forever, and clean the smallest hole/threads there are. As one member said, the flash hole in my brass is better than new. If someone would like try it, I'll send you my vibratory tumbler for shipping cost. First come, first served. I'll keep the HF ultrasonic for my wife's jewelry, but the vibratory tumbler is up for grabs.
