Not in an A body, but I need some opinions. '86 Ramcharger, 4.10 gears, 727 trans w/stock converter.
My old setup, '90 360, 9.3:1 comp, cleaned up 208 heads w/stock 1.88/1.60 valves, 192/203, .459/.471 lift roller, 114LSA, RPM Airgap and headers, fed by a swapped in stock '89 2bbl TBI system.
New setup, same short block, Eddy RPM heads, 10.25 comp, a still mild 226/230, .530 lift roller, 110 LSA, Eddy MPFI which uses the Vic Jr intake, same headers. I degreed the cam etc.
This thing is a soggy turd below 2500. Wooding the throttle won't even kick rocks in the dirt from a dead stop. I spent some phone time with Edelbrock tech getting the tune pretty close. New base map and some tweaks. Runs fine, just a turd off idle.
My old setup pulled better with the 30+ year old untunable TBI. A lot better. Spent close to $6k on this thing, one would think it would at least match a 30 year old system that was never known for it's power making abilities.
The rpm range of the Vic Jr starts at 3500, thinking I have a port velocity issue due to the big assed intake.
Your thoughts?
Your thoughts?
