The runner at the plenum should be bigger than at the manifold face. Some times it's hard to do with out welding.
Intake porting is some of the most time consuming, frustrating, compromising way to make power there is. It's worth it. I should have done more welding on my intake and I had to do some compromising.
Yes, but like I said, it's hard to do even with welding because the runners are relatively short compared to a tunnel ram. Sometimes, the best you can do is keep the cross section as equal as you can and damn sure you don't want the port at the intake bigger than the port where it meets the plenum.
