Vin info
Terry Dingwell
Active Member
Alberta
Hi all
Hope this question is in the right place. Can anyone help me out with what each VIN number and letter means as to gaining info of the vehicle. I have a (I’ve been told) a 72 Demon. Looking to see if it’s year correct, original engine size etc. Thanks!!
Look for the fender tag on the LF inner fender, that will give you more information.
Hi all
Can't find the gold if you don't have a map. Post up a picture of that tag.
Scroll down to the 1972 model year in the link below, and see what you come up with. The VIN will be on the dash tag, drivers side door sticker, data plate on the drivers side inner front fender, the radiator support, and the metal frame of the package tray under the back glass, near the drivers side speaker hole. Good luck.
