Vin number locations
gtxdude
Bloomington, MN
On 65 Dart ,is the Sequence Order (S.O.) on radiator support supposed to match fender tag & vin tag? or does it match one and not the other? I'm trying to find some numbers here and when I do I'm curious what goes with what. I know it changes with different years so not sure what mine should be. thanks
There was a thread on this the other day No part of the VIN is anywhere but the door post before 68
the hidden vin pre 69 should in part match the SO/ VON number.
it is formatted as such year or car single digit, factory of car assembly single digit, scheduled production date month and day, so number. It could read like 524I3022I9 with oct=a nov=b and dec=c and a 1 will be an I.
You can only tie the fender tag to the body to tie the vin to the body you need a broadcast sheet or build card from Chrysler Historical, which you can order for car 67 and earlier.
