Instead of discussing it in a sale thread I thought I would ask here. Front of the block, drivers side deck surface or above the pan rail? Photos or it didn't happen.
I struggled using "VIN" in the title because that information changed depending on what year. Thanks for the info.In 68 the vin is on the dash and fender tag. Body sequence number everywhere else. IIRC.
I worked at a restoration shop and the Secretary of State Police came in to do an audit and found several dashes off cars to be done. They were going to confiscate one out of a 68 because they could not find the VIN numbers on the body that was sitting next to it. I had to explain to them about the VIN and SO numbers, they had NO idea! After I did, the cop in charge asked me if I could teach a class to his other deputies so they knew about cars before 1969...Thinking about it, the vin ties the car to what it “is” through the fender tag. Nothing ties it to the body sequence number except paper work. Build sheet? I’m not sure what is on the warranty certicard. I will look at mine. Never had an issue, but always thought it was going to be difficult to explain to my local DMV guy why the number on the dash isn’t the same the number on the core support.
