They have a 4.00 inch bore and look to be no more than .037 thick. A good option for someone who is looking for gaskets that won’t kill your compression.
They look familiarView attachment 1715852834 View attachment 1715852832 View attachment 1715852821 View attachment 1715852822 View attachment 1715852823 View attachment 1715852824 View attachment 1715852825 Just thought I’d let anyone that may be interested in on something I found in the eBay archives. Found in a search for NOS & Military surplus head gaskets.
Thanks George. I surfaced the heads and deck and used those ony 273. 10 years and still going strong.All Kinds of these Mr Gasket 1121G head gaskets for the 318s on ebay.
Smaller Bore and .028 compressed.
Correct again! These are superseded by a later part number that are essentially the same gasket. It shows up as a dodge M880 (1977-1980) 318/360 head gasket.
Those are not steel head gaskets. They are composition style. They are no different than say some of the Fel Pros or Mr Gasket stuff in terms of gasket thickness or material. They might be different as for bore size, which a lot of people would probably be interested in because those smaller bore gaskets are kinda hard to find. Maybe somebody should get with Cometic and see if they'd make a run of them. I bet they might.View attachment 1715852834 View attachment 1715852832 View attachment 1715852821 View attachment 1715852822 View attachment 1715852823 View attachment 1715852824 View attachment 1715852825 Just thought I’d let anyone that may be interested in on something I found in the eBay archives. Found in a search for NOS & Military surplus head gaskets.
Yeah, but those have a huge gasket bore size compared to the 4" bore gaskets Garrett linked to.Here are the Mr Gasket 1121G head gaskets fitting up on a 360 application.
I see the small bore size though as an advantage for the 318 and 273 guys. You cannot find them with that small a bore size now. Smallest I see off the shelf is like a 4.040 and that's an almost 100 buck a piece Cometic.Looks like the head gaskets you would see on van 318/360 from 80's.
