hey everyone! will volare front disk brakes swap onto my 64 dart? not sure what year the volare is. its in a junkyard but everything is there.
thanks!
-tim
The F bodies have different geometry and will cause your car to have bump steer (if you bounce the front end up or down the wheels turn just like you turn the steering wheel). NOT reccommended. See this link. http://www.moparts.com/Tech/tech/pages/abody.html
Some people say the volare/aspen spindles dont give the correct steering geometry, but then other folks seem to be using these parts in their A bodies with no issues.
I'am using the spindles off of a 85 5th Ave. They are the same as the volare. I looked at this sight and decided to go with them due to their excellent work through of the differences
We have used a 78 donor disc set up on a 68 B body and did not notice the bump steer. The good thing is there are many 76-78 volares etc as donor cars.
