Voltage from ingnition to starter relay?
D Cluley
Lansing MI
1974 Dart w 318
I have not had a chance to get a FSM yet, so am hoping someone can answer a couple of questions.
When I start the engine and release the key back to the run position, the starter continues to crank.
What I've found is that the ignition wire at the starter relay gets 12v when the key is turned to start (that seems normal) but whenever the key is on, it is getting about 6-7 volts. That is not enough to trigger the starter relay, but seems to be enough to hold it once activated.
This seems odd, but I know that '74s had all the seatbelt interlock stuff (which seems to be unplugged on mine) so is that low voltage to the relay normal (in which case I guess the relay has gone bad) or is something feeding voltage to that wire that shouldn't be?
Possibly connected with this, there is a relay on the inner fender right by the ECM, that has been unplugged and a jumper inserted into the plug. This seems to be the wire to the starter relay. Am I correct in assuming that this is part of the seatbelt setup?
Thanks,
Dan
In the start position the ignition should see a full 12 volts, 6-7 volts to the ignition in the run position is normal. That means the ballast resistor is good and doing its job. What is referred to as the starter relay switches the ballast resistor in and out of the coil feed circuit. You have a 6V coil. Chrysler did this to improve cold starting by temporarily running a 6V ignition on 12 volts (which drops to 8 or 9 when cranking).
The only components that can cause the starter to engage are the ignition switch and the seatbelt interlock. Sounds like the switch is working, so that only leaves the interlock system. If you really want to keep the interlock you will have to find a good control box, sounds like yours is bad. If I knew where my old Charger was I could get you one. Never used the interlock on that one since it was disabled before I drove it off the dealership lot. The dealership couldn't disconnect them but I was told which plug to unplug when I bought the car. According to the service manager, the seat sensors had to be disconnected to disable the system without causing problems. The problem you are experiencing was one of the reasons the interlock system was a one year deal. The only good thing I can say about the system is that it got my girlfriend to wear her seatbelt. Never told her it was disconnected.
I second that motoion.
