JCNathan
Member
I have a 1970 340 Duster with the Rallye instrument panel. Voltage limiter is bad -- at least I think so...the fuel, temp gauges don't read correctly. The fuel gauge will read empty when I have 1/2 full tank. I've checked and replaced the sending unit and the resistance now is per spec. Also, the temp gauge bearly reaches the operating range when the engine is comfortably warm. If indeed it is the voltage limiter -- where can I get one? Does anyone have one for sale? Hep, hep...the "cruise" season is getting close!!!
