[Found!] W2 dual plane intake
Duel - stand back to back, take 10 paces, turn, aim, shoot!
Dual - two of something, like a dual plane manifold...
Yep
The cast iron manifolds were simply stock spread bore ones with w2 spacing of bolt holes. I assume the end user would port for their specific needs .
That cast iron intake was exactly as described to fit the “rules” of some circle track arenas. Otherwise, I have not seen a cast iron W2 with oval ports. Only in aluminum.
