[FOR SALE] W2 heads
badlilred79
badred360
Crossville TN
Rating - 98.4%
63   1   0
I have a set of W2 econo head part number 387-0810e econo W-2 with pedestals bear heads $650 plus shipping Crossville Tennessee
@go-fish I do believe these are what your looking for.
These are “810” heads with dual pattern exhaust holes for normal and wide header bolt spacing flanges.
Rockers for the milled rocker stands are available from Harlandsharp, TD and Jesel in 1.5 or 1.6 unless you custom order differently from TD or Jesel. Harlandsharp has 1.5 & 1.6.
Very interested. Any work done to the heads other than the pedestals cut down? Any cracks or repairs?
I'm taking the heads to the machine shop tomorrow to have a magnaflux they it looks like it's never been ported if you look inside the exhaust and intake ports the rough castings are no polishing the valve I stuck some valves in there the valve guides feel tight to me I got some extra I took a wire wheel and tried to buff up some not the surface rust off you can see where the wire wheel was
Okay the W-2 heads went from machine shop they are crack free and they are flat as .oo1 out from been perfectand a straightness on the cross side of the heads. The heads are $650 in Crossville Tennessee you want the heads it cost me $100 to get the heads magnifying check today the heads will be up for sale till Friday I'm going out of state to work look at the other ad for the pictures
I don't know if they were deck but they were flat it was within 001 I've been perfectly flat I did not notice any crack repairs or anything like that
