W5 heads T&D Rockers
spdge70
Rating - 0%
0   0   0
Blue Plug W5 Heads, never used, port matched W5 short runner intake, T&D Roller Rockers 1.7 ratio. Cometic Head Gasket, Fabricated Aluminum valve covers, gaskets. Everything new.
CNC port Pr W5 heads, hand blend in exhaust seats/intake bolt holes
SDSS 5 angle competition valve job 2.08”/1.60”
Remove 16 3/8 guides, ream holes to .500”
Install 16 Bronze guides hone to .0015” oil clearance
Drill oil drainbacks in 16 spring pockets on W5 heads
Machine rocker pedestals for T&D rocker system
Resurface pair W5 heads .040”
Port match MP M1 SM Runner to W5 ports
Pressure Test Pr W5 heads
Clean & assemble Pr W5 heads
PARTS
ISKY 9995 Tool room Gold Stipe roller valve springs
Ferrea F1238P/F2218P 2.08”/1.60” Stainless comp plus valves
Comp 1732-16 Tool steel retainers
Crower -.050” 10 degree moly valve locks
Durabond HP series hardened spring shims
Viton 11/32” valve seals
CV Products 11/32” X .502” valve guides
Springs setup at 2.00” IH, ~265 on seat, 625# open @ .700” lift
$6000.00 OR BEST OFFER
The CSR Water pump and Spacer have been sold. I am looking for 5000.00 for the heads, intake, rockers, valve cover and gaskets. Everything new and ready to be used.
