yellow73dart
Ok heres what I've got. Its a 72 demon. I'm putting a 318 in it for now with hopes for something bigger later. I already have a very strong 318, 904 combo. I also have a factory 318 k-member out of a 74 swinger. I took the large bolt pattern disc brakes and 8 1/4 rear end while I was at it. Now to make it work right. I want to make handle as good or better than a new car off the lot. Should I go with factory rubber with a sway bar or poly? What size sway bar should I use or does it really need one? What about bushings for the rear springs? What are your thoughts for a very reliable street car that may see a little bit of fun every now and then?
