[WANTED] Wanted 1966 273 motor or heads
rdoylejr
Active Member
Rating - 0%
0   0   0
Hello: I am looking for a 1966 273 motor or heads. The heads must have a casting code # 2536178 or 2658243 or 2658920. I already have a date correct block but I would consider a whole motor. I live in Waterford Michigan. Thank you. Bob
hey this is jon I talked to you the other morning , there is 1 for sale tonight under new posts . if you don't find it search 65,66 273 engine for sale gl
Thanks Jon it turns out it is a 1965 motor. I guess I will have to keep on looking.
I have a 67 273 I parted out but I'm in Chicago. pretty sure it has 920 heads
hello, i have a friend who has a 66 273 block and pistons, came from a 66 coronet with a 2bbl intake and 904 trans. real early 66 model engine, cast mid august 1965. let me know if your interested. located in arkansas.
Hello Soda-pop. Thank you but I don't think that will work. shipping will be to expensive
Did you find them yet??? I have a pair of 2658920 heads......I am in San Diego but there are ways of shipping that are economical.......let me know if you still need them
I have a set of 8920s that were removed from a 67 318 I bought from another FABO member. Recent valve job, guides are good, 1.75 int valves backcut, 1.5 ext valves. I'm in FL.
