Wanted: 65 Barracuda lower control arm
I have numerous lca-- none with the tab-- all for the 62-72 models. (69dartcv@cox.net)
I'm cleaning shop so price will be good
Hi, the lower control arm has separated from the mount at the torsion bar end. Not sure, but I suspect an earlier hit on the arm caused the damage. Do you know if it was originally welded or press onto the torsion bar mount? The sway bar mount at the arm is not damaged, but I see it was factory welded to the arm. Not sure how successful it would be to grind the weld and reweld to an arm without the tab.
When I remove the arm. I may try to repair it.
Thanks for the help,
Pat
