[WANTED] wanted.68-69 340 engine brackets
Yeah what he said 340/360 same on drivers side ...318 is different different Drivers side only. Passenger side are all the same
I have a set that are old but may work for you. Check of the pictures and PM me if you need / want them.
Stay away from the conversion mfg mounts.
I paid 70 bucks for one.
The alignment was off, had to shim the mount to get the trans mount to line up.
After a few races, the aftermarket mount bent.
I took the 318 left mount, bolted it to the engine.
Cut up an extra mount & aligned it with the back ear on the block.
Welded it to the 318 mount, no problems at all.
