looking for the 2 brackets that bolt to the k-member that the sway bar mounts to on a 68 barracuda.other a-bodies should be the same i would think.thanks.
Those sway bars came with the hanger brackets and bushings already on them. They weren't removeable/replaceable unless someone has aftermarket kits for them now?
Tough to find good not smashed originals. Energy does selll a replacement poly bushing for originals. Tough to install. Most people cut the bracket and reweld the end to replace with the poly insert.
