Wanted: Revised ad--14" steel sbp wheel
6-david-5
Mopars under construction
Magic Mountaindale
I need TWO small bolt pattern steel wheels. I believe they are the 5.5"-wide steelies. I'm in SoCal, and am willing to take a drive depending on where you are. Please see attached photos. I'm looking for the match to that wheel.
Note: I may consider the 4.5"-wide wheels, but then I would need to run spacers for my disk brake conversion, or grind the calipers, which I would prefer not to do. So, I would prefer the wider ones because they clear.
Big thanks.
I have a couple or one sbp steelie wheels. 5.5 wide. Msg me if interested I'm in Arkansas.
