At a quick glance, I see.....
A low compression 3.38 stroke engine, with real nice bolt on's, and a cam that will soften the bottom end, but make some power in the upper mid range thru the top end.
I'll be real conservative, and say you're in the 325hp range...You have a tall tire, but the 4.56's should put you in a very good spot. Knowing the actual weight of the car would help a lot?
So here's where I'm at.....Your (torque converter/stall speed) will make or break a combo like this as far as et's. If it's a stock or a lower stall speed, the most you can do is run as much timing down low in the curve as you can to help you get going, meaning 60' times. If by chance you have or are going to step the converter, I think you'll get some respectable times out of it.
At this point, I think you have the potential go 8.0's in the 1/8th & 12.70's in the 1/4. But it really depends on the weight of the car, the converter, and the final combo.
Keep us informed, and supply as much info as you can going forward...
Good Luck, Rick
