Garza08
My motor is being built with this set up just looking for opinions in wat i will or should run first time ever doing a motor
Motor
- 360 block
- Holley strip dominator aluminum intake
- .040 bore over Keith Black hp190 pistons
- X-Heads 72 cc I think is wat the previous owner told me
- compression should be about 10.5 to 1
- stock crank has been turned and polished
- eagle piston rods
- summit headers
- dual super 40 flowmasters exhaust system
- right now I have a 650 carter 4 barrel carb
- aluminum radiator
904 stock tranny and stock converter
All this in a 1973 Duster with 14 in ralley wheels in the front and 15 in ralleys wheels in the back
All opinions would be appreciated or suggestions
Motor
- 360 block
- eagle piston rods
- summit headers
- aluminum radiator
