waterpump bypass hose
Eric Mulay
san luis obispo california
I have a Edelbrock 7577 intake on the 360 magnum and the LA style water pump, i have purchased 2 bypass hoses, both wont fit, they do not have the correct curve, ...
what has worked for you guys?
thanks
I've used this from dealership on a LA 273. Silicone lined.
That intake fitting comes off at a 90* angle unlike the LA style intakes that are more like a 45. You might have to trim the hose down a bit and muscle it on but it’ll go on ok.
As mentioned by 67dartgtgo, trim. Or as we use to say "if it don't fit, make it fit":)
View attachment 1715534250 That intake fitting comes off at a 90* angle unlike the LA style intakes that are more like a 45. You might have to trim the hose down a bit and muscle it on but it’ll go on ok.
I got it in.. But it had a good kink in it ..
Then i trimmed it.. Then i trimmed it again..
Then it was too short.
I see yours.. So.. Ill get another one. Try again.
You are gaining what is called "experience". You will win. Stay with it.
Two of these (One for Intake Manifold, on for water pump):
Mopar Perf. Intake Manifold Bypass Fitting Adapter #MOPP4876374
One of these:
Mancini Racing Intake Manifold Bypass Hose Kit #MRE4876373
Both from Mancini
