Weiand 8007 intake, LIKE NEW!
EL5DEMON340
Aurora,IL
Was told this intake was bolted on a 340 and ran for a few minutes before they had engine trouble. This Weiand 8007 action plus duel plane intake looks very nice, no alterations, porting ect. Also included is a cast iron t-stat housing looks new, also a hi-flow T-stat, tested it and it opens at aprox 183 deg, a vacuum tee, temp sending unit( not sure if good or not), and a good looking by-pass hose. $140 + shipping, Aurora, IL 60502. Thanks Mike.
Does that have 318 or 360 size ports?
I think its the smaller port 318 size, i was going to use this on my hot 360 but found a LD340, anyway i was told if going on a 340/360 that this intake is only necked down about an 1" in and to gasket match to the 340/360 head, the rest of the port is rather large and will work fine with a hotter 340/360 + cubic inch motor. the port window is smaller than the LD i picked up. Thanks Mike
