Weird Gasoline Leak Today. Thoughts on Cause and Source Appreciated
Fuel and Air Systems
  1. harrisonm
    harrisonm Well-Known Member
    2,591
    2418
    Jan 16, 2005
    Topeka, KS
    Local Time:
    10:58 AM
    I was working on a friend’s RV today, so I parked the Barracuda Way down at the bottom of the driveway to keep it out of the way and keep it accessible. When I went to pull it into the garage, I smelled the strong smell of gas. There was a good puddle behind the car, and more gas was dribbling out from the left side. I had just filled it up yesterday. It was much warmer today
    My first thought was that the donut gasket where the filler tube goes into the tank had sprung a leak. I looked underneath the left side, and the donut gasket area was dry.
    However, gas was dribbling out through the two rear-most holes in the left frame rail. I thought, “What could possibly cause that?” I was afraid that the warm weather and the full tank might have resulted in the fuel expanding enough to somehow get into the trunk.
    And OF COURSE the trunk lock picked today to break, so I drilled it out and used a screw driver. Trunk was dry. The leak stopped, and no more since. What the heck??? Any ideas wher the leak came from??
  2. Professor Fate
    Professor Fate Push the button, Max...
    735
    921
    Jan 13, 2020
    Wisconsin
    Local Time:
    4:58 AM
    I'll bet it's your tank vent. The vent hose goes from the nipple on the filler neck, makes a high loop up the C pillar, and follows the filler neck back down through the trunk floor, ending inside the frame rail.
    The heat made the fuel expand, pushing it out the vent tube, and it leaked out of your frame rail. Hey, it was just marking it's territory.
    • Agree Agree x 10
    • Like Like x 1
    • Thanks! Thanks! x 1
    • pishta
      pishta I know I'm right....
      17,291
      6906
      Oct 13, 2004
      Tustin, CA
      Local Time:
      2:58 AM
      I think you nailed it.
      • Agree Agree x 2
      • Demonic
        Demonic Well-Known Member
        1,250
        981
        Mar 21, 2015
        Maryland
        Local Time:
        5:58 AM
        My 69 Charger has the vent in the frame rail also, had the same thing happen once. The big temperature swings in spring from night to day help too.
      • harrisonm
        2,591
        2418
        Jan 16, 2005
        Topeka, KS
        Local Time:
        10:58 AM
        Thanks. That makes total sense. I think I'll just go out today and drive a few gallons out of it. That should take care of it.
        • Like Like x 1
        • Tinmannz
          Tinmannz Well-Known Member
          224
          237
          Jul 29, 2019
          'Lost in Space'
          Local Time:
          3:58 AM
          Sounds like an excuse to me! The perfect excuse to get out and drive to put a smile on your face that is.:thumbsup:
          • Agree Agree x 2
          • famous bob
            famous bob mopar misfit FABO Gold Member
            16,596
            6375
            Aug 14, 2011
            okla
            Local Time:
            4:58 AM
            Also on a grade -------------
            • diymirage
              diymirage HP@idle > hondaHP@redline
              19,074
              12892
              Oct 12, 2012
              michigan
              Local Time:
              5:58 AM
              did you get the gas at the same place as usual?
              maybe she didnt like it?
              thats what my kids do when you try to feed them something they dont like
              • Like Like x 1
              • 67Dart273
                67Dart273 FABO Gold Member FABO Gold Member
                42,927
                10498
                Oct 14, 2010
                Idaho
                Local Time:
                2:58 AM
                It's the vent and it's doing exactly what it's supposed to do. I'm not familiar with the fish body but I'd guess the vent does not elbow up "quite as high" as the other A's. The conventional bodies, the vent leaves the filer tube and loops up pretty much against the underside of the top of the quarter panel, then back down. So you'd have to get them REALLY full to get them to siphon much out. The filler is designed as a "vacuum break" so that as soon as warming fuel is pushed out down to the vent connection, it "breaks" and stops
