Hey guys just picked up a mig welder but ha no tank wats the best gas to run ? Argon ?this is for panels and roll cage stuff like that . Just not sure on the wat tank I should get?
You'll see an 80/20 CO2 Argon mix too. Just go to your welding supplier and buy (lease) a medium sized cylinder of gas. After you use that one it's on exchange for about $50. It'll last you quite awhile - as long as you remember to close the bottle valve when you're not using it
