1966 dart wagon
well i finally got out to a parts yard around here and i found a couple things, first off i believe i found a 8 1/4 rear end out of a scamp(dont recall year), woo well i got a pic for confirm, and will this directly bolt up to my 7 1/4 rear end(maybe drive shaft mods) ? secondly i found a big bolt disc brake system out of a valent(sp?) the guy said they are both bbp, but i cant confirm, he said the rear axle drum to drum is 125 and the disc brake setup with whole thing including spindal and uca, is 150.
i was pretty sure the rear end was well worth it especially if it bolts right up. Any suggestions on this setup.
oh and while i was looking around i found an original conversion kit for electronic ign. parts in box! wo, just though it was cool :thumbup:
White car has disc brakes, green has the rear
o i can get a 73+k frame (drum to drum) for $75 its pretty rusty though, and what should i all get for the disc swap i read the moparts article and was still a lil confused, i need the porp. valve(should i just get a new one prolly be worn out) same with master cylinder...should i just snag the one on the car and use it as a core?
o and btw i pulled the heads of the 360, and well all the places ive looked (online) have the wrong number i have no 1 in mine, so it says
3418915 360 1970-72 1.88 1.60
http://img154.imageshack.us/my.php?image=0320071116ur5.jpg
just curious as to why its like that?
