Wet Sanding vs Dry Sanding
mokid
SW MO
If I wet sand body filler (bondo, mud, whatever name you like) and spot putty (two part mix), will it retain moisture and cause rust problems later? It would be bare metal beneath the filler..........tx..........james
Do not wet sand body filler of any sort. You can wet sand primer surfacer, clears, and base coats when needed.
What they said.
To answer your question, yes - the bondo will absorb moisture and cause you grief down the road with both the paint on top of it and rusting the metal underneath it.
You only need to sand the bondo down to 180 grit and top that with some 2K hibuild primer. Dry sand that with 180, take care of any high & low spots, primer again, repeat this process until you are happy with the results, then wet sand.
C
That's what I thought, but was looking for other opinions. What you guys said makes good sense............tks...........james
