What are the best roller rockers for Magnum heads ?
RedB.
down south
I am Building a 360 Magnum basically a stock rebuild on the bottom end with ported magnum heads and regrind cam {Oregon } have not decided on the grind yet, Hughes 1110 valve springs. So my question is maybe roller rockers or just stock factory rockers ?
The stock factory rockers are fine with the 1110 springs.
I have used a stud/guide kit that allows you to use (cheap) chevy rockers on a magnum head. I have edelbrock heads now that require the same chevy rockers.
