What brake set up do I have ?
RON REAGLE
BEAVER FALLS PA
My 65 Barracuda has been converted to big bolt pattern front disc brakes. I assume these are 72 and up a body disc's ? So would I also have the big ball joint as well ?
The slider type, like from a 78 and up Corvoba or even a larger car. And yes the large ball joint
Theres several different calipers based on piston size and banjo fitting location
73-76 A,B,E 2.60" diameter piston
78-79 B,C 2.75" diameter piston
Both of these have the same hose fitting location, just bore size is different
Then you have 77-89 FMJ calipers. These bolt on the same way as the A,B,C calipers, but the banjo fitting location is positioned differently, also depending on the year and model the pistons are sized differently. 84-89 M body use the same 2.75" piston as the 78-79 B,C body cars
I could be wrong with some of this information. I try to be factually correct.
