eric202006
just got back from the track firtst time out
what can i do to make my duster hook up?
446ci iron big block (501hp 527ft)
dynamic custom converter flashes at 3800
4.56 gear
275/60 M/T drag radials 10lb and then 8lbs
cal-tracs too
i tried leaving at 3000,2800,2000, idle
1st pass
60ft 2.459
1/8 8.570
Mph 92.28
roasted the tires leaving at 3000
2nd pass
60ft 2.108
1/8 8.20
mph 88.73
rolled out then gradually got into it since i roasted the tires so bad. and go swirly on the other end
3rd pass
60ft 2.09
1/8 8.104
mph 90.50
i left around 2000. it felt better than the first converter pass but still spun really bad. but i could feel it pulling good on the top end.
last pass of the night against a 5 speed mustang
won on the tree .427 to a 752 leaving at 2500
60ft 2.15
1/8 8.19
mph 88.58
night time in the cold. car was all over the track. it felt like the car pulled its hardest. and set it spun bad this time too. the only thing different is i didnt feather out the spinning.
im thinking of get slicks and trying it again. do yall think i have too much tension on the cal tracs. what shock should i use.ale:
HELP ME
4.56 gear
cal-tracs too
1st pass
60ft 2.459
1/8 8.570
Mph 92.28
2nd pass
60ft 2.108
1/8 8.20
mph 88.73
3rd pass
60ft 2.09
1/8 8.104
mph 90.50
60ft 2.15
1/8 8.19
mph 88.58
HELP ME
