What fluid for 4spd OD?
Brad54
I've searched just about every place I can think of to find out what fluid to put in the New Process 4spd OD trans I've got, and get everything from "Gear Lube" to "ATF" to "Dextron" to various mixtures of all.
What are you guys running in your A-833 ODs?
I've got a howl in 4th gear, and if damage isn't already done (meaning the howl hasn't set into the gear teeth and is now permanent), I'm hoping the proper lubricant will quiet it down.
-Brad
