What flywheel ,behind a typical Mopar musclecar bellhousing.....?
Abodybomber
Breaking street machines , since 1983.....:)
Legendary Member
Arroyo grande ca
Always wondered,what is the most viable flywheel/clutch option,behind a 833 & a LA bellhousing? Heard the Magnum truck flywheel doesn't clear,the stock older bellhousing. Any knowledge ?......
I believe mopar makes a 130T flywheel with the magnum balance.
mcleod makes the one I used. has bolt on weights that cover internal balance, external balance and magnum.
