What flywheel is this?
Mopar92
Lewisburg tn
I googled the part number and my gosh. I found everything from 143 tooth 383 to 130 tooth 360. I tried to just find the part number and obviously am google failing tonight. Little help would be appreciated. Thanks.
Looks like an externally balanced flywheel.
So are you gonna share this mysterious part number or do you expect us to read small, upside down and out of focus numbers? I mean seriously, you ask for help then leave out valuable information.
Well, my phone zooms in on the pic quite easily.
Here is a quote from our friend IQ52 from the DodgeCharger forums.
"If those three balancing holes are 31/32" in diameter and .66" deep the flywheel is for a cast crank 383/400/440.
If they are 1-13/64" in diameter and .66" deep, the flywheel will be for a 360"
Pretty self explanatory.
I don't have it here to measure. Only the pics. It's 143 tooth I just learned so I'm out. Need a 130t
RRR you need glasses I can read that plain as day.
